跳转到主内容
加入维修社区 - 创建账户
第六代 Apple iPad (Wi-Fi 版) 的维修指南、拆解信息和故障排除资料,提供 32 GB 或 128 GB 存储空间可选。于 2018 年 3 月发布。型号为 A1893。配备 9.7 英寸 Retina 显示屏和 64 位 A10 Fusion 芯片。
Part of screen not touch responsive after display replacement
Thank you for your guide. I’m almost finished but before closing the screen to the frame I’m testing whether the touch works. But on the unlock screen all numbers but 1, 2 and 3 work. What could cause this problem? I have installed the kapton tape on the replacement screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Did you unhook the battery before you took off the screen and reinstalled it? Unhook the battery and disconnect the screen connector and get a magnifying glass and see if the pins were damaged. If they are ok on both connectors than take a qtip with a little alcohol and clean the connectors then brush them off with a soft brush. Reconnect and try it again
这个答案有帮助吗?
得分 2
添加一条评论
Hey Allan Barr,
Thx for your comment, I also had small part of the touchscreen that did not responded.
Followed your steps and it’s working 100% now.
Thank you for your contribution!
Grtz
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michel Braamhaar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 918
