跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Battery compatibility. A1494 vs A1618
Hi.
I cant figure out the compatibility of macbook battery in the late 2013 - mid 2015 A1398 models.
Will a battery with model number A1494 fit a 2015 A1398 MBP? Or will i need a newer battery with model number A1618?
Some sites / vendors says the A1494 will fit, some says it does not. I get the difference in the mAh. 8440 mAh in A1494 and 8740 in A1618.
Can anyone clarify?
Thanks a lot!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
If you review the iFixit batteries
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery
MacBook Pro 15" Retina (Mid 2015) Battery
You’ll see the power values are different!
While Apple did stick with the same dimensions and the connection to the logic board is the same for both. The chemistry of the batteries is different as such the charging rate programed in micro-controller and SMC what match up properly. I suspect some of the battery failures we have seen are do to the wrong battery being used.
Replace a 8700 mAh battery compatible with MacBook Pro 15" Retina (Late 2013/Mid 2014). 98 Watt Hours (Wh), 11.26 Volts (V).图片
产品
$89.99
Replace a 8800 mAh battery compatible with a MacBook Pro 15" Retina (Mid 2015). 99 Watt Hours (Wh), 11.26 Volts (V.)图片
产品
$109.99
这个答案有帮助吗?
得分 4
9条评论:
I see, Thats probably quite relevant.
thanks for the reply Dan!
完成的
@ajes - Don't forget to score the answer and accept it - Thanks!
完成的
@danj - From late 2012 when new type of battery was introduced and apple started glueing them in, is calibration not required anymore? And if not why is this when "old" types in 2010 - 2012 did need it.
Better monitor software or different batteries?
Calibration = Charging battery full 100% + 4-5 extra hours, draining bat through normal use and charge again.
I have replaced battery in some A1278 sometimes the replace battery message comes within a year and a calib + SMC reset usually helps.
完成的
I calibrate the batteries I put in. Apple still does it as far as I know, so I have no idea why you think it's not done.
Calibrating a battery later doesn't really change things. All you are doing is resetting the high and low water points, over time they will drift back to where you had them before you re-did the calibration. Yes, it does appear to improve things but at the risk of overheating your battery.
完成的
Hi Dan and Anders
Would it be possible to use the A1618 battery (with 99Wh capacity) in a Macbook Pro 15 Retina Mid-2014 that's originally fitted with a 95Wh battery?
完成的
显示更多的4条评论
添加一条评论
Actually, the power rating is showing up as 99Wh in both of those links. I don't know if it is a recent typo.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anders Laursen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 54
总计 4,907
