跳转到主内容
加入维修社区 - 创建账户
Asus Zenbook 由华硕电脑股份有限公司制造,于 2015 年发布。它采用 13.3 英寸触控屏,并配有防眩光哑光涂层。其型号为 UX303U。
How to replace keyboard?
Is it necessary to replace all front panel or is there a way to replace only the keyboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It looks like it is integrated into the uppercase:
https://www.ebay.com/i/223782675296?chn=...
这个答案有帮助吗?
得分 0
添加一条评论
I just replaced the keyboard on a Asus UX303UB and it is possible but there are no guides that show this process. I used the existing guides to open the case and take out the battery. The rest was done by logic hope and luck. The model I took apart had 2 fans, and 2 heat sink and also required me to break out the old keyboard. There is a youtube showing this but it is not an ifixit video. My internal layout was a bit different as well. It has12 gig Ram and a 2.5 inch SSD also in the computer.
The keyboard replacement fit perfectly over the studs left from the old board which was held in by the studs which were melted to hold the board in. The spludger worked great to pry it off but it was scary and I did it only because the original key board had 2 broken keys, one being the off/on key. The replacement key board fit and is held in by the brackets and mother board and cooling systems and I can not see that the melted studs were essential to the function, maybe done to aid in its original construction. Definitely not for a machine in warranty but mine was 5 years old so I gave it a try.
这个答案有帮助吗?
得分 0
1条评论:
Also require the removal of both motherboards and the screen.
由完成的 分享
添加一条评论
添加你的答案
andreatoschetti 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 692
