跳转到主内容
12.1" netbook has an AMD E450 APU running at 1.65 Ghz, Radeon HD 6250 graphics, 1366 x 768 screen resolution, release in April 2011.
2 个问题 查看全部
Asus 1215B does not charge the battery.
Hi, I have a problem with my Asus. When I plug in the power supply, the battery doesn't charge. The power supply has the correct voltage. I'm attaching the BatteryMon screenshot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If it’s an older laptop, most likely the battery will need to be replaced. Batteries are consumable items whether it’s a TV remote or a car battery, it’ll need to get replaced at some point.
这个答案有帮助吗?
得分 0
评论:
BatteryMon shows a voltage of ~7V to 8V and the battery should be 10.8V. So it's probably due to the battery?
完成的
Most likely a dead cell then, so yes a bad battery. And voltage is a measurement of charge, not capacity. A bad battery can show gold voltage but as soon as you put a load on it, that voltage can drop.
完成的
添加一条评论
hi
you need to replace laptop battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jan Kowalski 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 173
