跳转到主内容
型号A1288,闪存容量:8、16及32GB
Why is my iPod not turning on when I charge it?
went on a camping trip (worst ever!) i dropped my i pod in the beach water for mear seconds, let it sit to dry and it worked fine later at night. the next day i got dropped off at my home and as i was getting off my car, My ipod dropped to the cement falling on the corner of the headphone plug. and now it wont start at all! PLZ HELP!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Raul, you have two issues going on here. do it systematically and start with the easy things. Try to reset your Touch by
Press and hold the Sleep/Wake button for a few seconds until the red "slide to power off" slider appears, and then slide the slider.
Press and hold the Sleep/Wake button until the Apple logo appears.
Make sure you have a full battery. Plug it into an AC charger, not your USB port.
Okay so if that does not do anything, it might be time to open up your ipod and check for any visible damage. Follow this guide to clean your iPod. At least, replace your battery. Once you have this accomplished, re-evaluate what works and what doesn't and let us know.
iPod Touch 2nd Generation Battery Replacement
iPod touch (2nd Gen) Battery
Replace a battery compatible with the second generation iPod touch model A1288. Part #616-0401. Model #616-0404. Installation requires soldering of battery to logic board.图片
产品
$14.99
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Raul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,046
