跳转到主内容
加入维修社区 - 创建账户
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
MacBook Pro 15'' 2011 doesnt turn on
Hey. laptop was working just fine. i went to sleep left laptop on charge and in the morning its just doesnt turn on anymore. If i try to reset smc it doesnt work its show green light on charger all the time. if i press battery indicator it starts to blink like 10 times but only one of the light’s . any ideas ? Its a1286 model with 2915 board
Update (03/29/2020)
by the way i did search on the board is antwhere is getting hot when i plug mag-safe. so the U7201 chip is getting really hot. Any ideas why? and if i would change it does it gonna help me or not ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
2个答案
最有帮助的答案
The 2011 MBP is known to have GPU problems, which is likely what you are seeing here. However, a 2012 board can be installed in lieu of scrapping the machine, providing you can get a good deal on one that’s nearly identical spec wise or a major bump (Ex: i5->i7). However, it may not boot without reinstalling the OS if you upgrade it too far, so bear that in mind. That said, MacOS is pretty forgiving about it unlike Windows.
You may also need to update the OS to get the current EFI updates, so I would try and save it for one or two final boots to make a backup (if possible, you may be able to bake the MLB to get the data off but this IS NOT REPAIR - it is a RECOVERY TECHNIQUE when all else fails). If you change the computer out, make sure you replace the HD cable while you’re in there - ESPECIALLY if you buy a 2012 15” to replace it. It doesn’t add much cost and it puts the all too common cable issue to bed when you will eventually want to replace the original drive with an SSD.
More then likely, it’s going to be easier to get a 2012 machine and migrate the hard drive. Just be prepared to pay since these are prized machines unlike the 13” which comes and goes like it’s a dime a dozen - the HR AG machines are even more prized then the common base glossy ones so if you want that screen, you’re paying a good $1-200 more for it.
这个答案有帮助吗?
得分 2
2条评论:
so is there any way to test if there is gpu problem 100% ? Cuz as i know there is possible to upgrade bios to disconect second gpu. U can make it by connecting the chip or just taking some wiring on board. But i just dont know how could i check if its gpu. I do get green light of charger but no fan spin or etc. was looking to board as well nothing bad on it as i can see without microscope.
完成的
@gbevardis If you have a no power condition, it may be too far gone. The problem is the 2011 board has a 100% death rate and there are no good parts to fix them - if the GPU dies, put a 2012 in or replace it. Don't buy them but if someone gives you a dead one I wouldn't hesitate to put a 2012 board in if the price was right - especially if it was the AG version.
I am migrating this to Answers, so if you do not see it check there. This is a repair question.
完成的
添加一条评论
Unplug the battery and mag-safe. Press and hold the power on button for 10 seconds. Reconnect the battery and then the mag-safe. You should get a spontaneous reboot. If you do have the GPU issue, DosDude has offered a couple of fixes:
gfxcard status https://gfx.io
here’s a discussion of the issue:
https://www.reddit.com/r/MacOS/comments/...
这个答案有帮助吗?
得分 0
1条评论:
battery and mag-safe unpluged pressing 10s power button and when i reconect battery and plug in mag-safe there is no green light on charger. until i release power button and replug the mag-safe . only then green light comes again. any ideas why .
完成的
添加一条评论
添加你的答案
Lukas Taujinskas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 170
