简介
Use this guide to replace the hard drive cable, which also contains the IR sensor and sleep indicator.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
19等其他人完成本指南。
4条评论
The cable is too long for my Samsung 8500 PRO SSD, and it blends under it. Also the CRC Error count is really high. Any help?
Great this is how I take it out. It would be great if there were some help putting it back in, as I am an idiot.
Hm, what step of reassembly is causing trouble, Phillip?
My understanding is that the original Apple cable tends to fail, slowing the speed of hard drive access, but not stopping it outright. I replaced the cable, and changed to a SSD hard drive, and now my machine is SCARY FAST!! Happy, happy. :)
