跳转到主内容
加入维修社区 - 创建账户
XM Satellite Ready & SIRIUS Satellite Ready 5-Channel A/V Receiver featuring HDMI. There are multiple versions of this receiver and the differences are usually negligible. Depending on which receiver you have, some repairs may be performed differently.
Volume knob Not working to raise Volume
So the when I turn the Volume knob up to increase the Volume it just goes down to negatives(ex….-1,-2,-3etc..)and I cannot get it past the 0 to raise it just goes into the negatives. The knob spins all the way around when it suppose to go up to 12oclock(+) and down to 6oclock (-) . I took it off try to push it in but cannot figure… Does anyone know how I can fix it??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Volume Control Potentiometer Cleaning
The grease often messes these things up - remove it with contact cleaner like DeoxIT D5 and it tends to solve the issue permanently. However, if it has been abused the switch may need to be replaced. I got mine for free and fixed it with a can of contact cleaner.
这个答案有帮助吗?
得分 1
添加一条评论
I bet that the sensor on this is clogged with dust or lint and cannot detect the beam interruption by rotating the control. Take the cover off and use canned or compressed air to clean the area aaround the volume control. I have also had this happen with a different unit (A Sony compact stereo).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert Nonestein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 3,821
