What year model parts are interchangable with an 2004 Chevrolet Tahoe
What year model parts are interchangeable with an 04 Chevrolet Tahoe 4 wheel drive 5.3 L engine
James McNeill to list all the parts that are interchangeable would be a tall order. We could probably provide you with an answer for a specific part but not for all of them. For that I would recommend that you try to get your hands on a Hollander Interchangeable Manual.
这个答案有帮助吗?
I have this question as well and let me see if I can ask it differently to get the answer that may help better.
What years match basically on a Tahoe Z71? Like 2003- or something like that. Matching down to specifics is ideal when you get there but examples would be a cluster, dash controls, window motors, seats, 5.3 motor and tranneys that would match up.
Will exhaust off 2001 Chevy Tahoe 5.3l engine 4 wheel drive, Fit on 2004 Chevy Tahoe 5.3 4Wheel drive
What year makes and models will fit a 2000 Chevy Tahoe Z71 like alternator
I have a 04 Tahoe that needs a steering box can I use an 02 suburban steering box
Will the hood and grill from a 2003 avalanche fit a 2003 tahoe z71
My 2002 yukon frame is rusted out and was wanting to do a frame swap can i use a tahoe frame from the sam era?
这个答案有帮助吗?
Will a engine compartment hood for an 04 Chevy Silverado fit a 04 trailblazer
Disregard engine compartment Hood Silverado to trailblazer does not fit
Does the transmission from a 2001 chevy tahoe LS,fit a 2004 chevy tahoe Ls?
@michaelgut59688 yes
Will 3rd row seats from a 2004 Tahoe fit a 2008 Tahoe?
From my understanding most Chevy Silverado's in Chevy Tahoe's from do believe 99 or 2000 don't take my word for it but I think it's 2000- 2004 are almost exact same and I think Cadillac Escalade also is in that budget of things not every part will fit but for the most part that' if the engine an transmission are same most parts would fit it but i do belive 2000-20054 . I been going by this for 5 years now and it has not let me down yet . I have a 2000 tahoe 5.3 4x4 with 6 in lift 3 in body . On 37s swampers and 22 rims custom . Ol bettsy a bad beech been thru 3 floods and 6 hurricans / tornados and still.runnin like a champ and it was just flooded to the whindsheld and everything still workin other than the driver seat lmfao
这个答案有帮助吗?
I'm trying to find out if a 2004 Suburban drivers door will fit on my 2001 Tahoe
Is a 2007 chevy tahoe 2 wheel drive cv interchangeable with that of a 4 wheel drive
Will a 05 Silverado with a v6 rear end swap with a 05 Taho with a 5.3 v8?
2004 Chevy Tahoe was badged as a GMC Yukon with the mechanical parts being the same. The difference in the 2 was in the trim lines with the Tahoe having more variations on interior & exterior options. Mud Guards, Upholstery, Radio Upgrades, and the like.
这个答案有帮助吗?
I have a parts vehicle 2001 chevy tahoe. Several doors,rear hatches have 2,all interior, seats aren't going. This vehicle has a new motor 5.3 bored 40 over.and a new transfer case, shocks,brake lines straight from GM ,was a kit $850.etc
Can I take a 09 Chevy Tahoe motor out and put it in a 04 Tahoe
09 is gen iv 58x crank reluctor and 04 is gen iii 24x crank reluctor. Not without removing the crank and changing the reluctor wheel and the crank sensor
I have a 2004 Chevy Tahoe z71 and I’m in the process of buying a complete upper intake manifold from eBay will a 2005-2006 upper intake manifold fit my 2004 ?please help me out !!
这个答案有帮助吗?
yes, any cathedral head intake will
Frames are different along with the location of the body mounts. It would be an expensive custom job.
这个答案有帮助吗?
Are the pillars interchangeable on a 2003 Chevy Tahoe and a 2004 Chevy Tahoe
这个答案有帮助吗?
Is the transmission interchangeable between an 02 Tahoe 2wd and a 05 chevy suburban 2wd both 5.3L
过去 24 小时: 9
过去 7 天: 71
过去 30 天: 321
总计 54,118
14条评论
Can I add to this and ask will a 2005 4x4 tahoe with a 5.3 be a match to a 2000 tahoe 4x4 with a 5.3 i want to pull the whole brake system rear end motor trans and some body parts from the 05 for my 2000 i should be good right? I know motor and trans are
由 Brandon Luse 完成的
2009 avalanche fender and passenger doors front and back. Looking for something interchangeable
由 Carlton Davis 完成的
Does Radiator and transmission cooler fit from a 2009 to put in my 2004
由 Keith Beard 完成的
Is there a way to install a headlight and tail light assembly from a 2005 Chevy Tahoe on a 1999 Chevy Tahoe LT?
由 ccarroll0521 完成的
Is an 04 Silverado 1500 the same as an 04 Tahoe as far as suspension goes
由 Ant Dogg 完成的
显示更多的9条评论
