跳转到主内容
加入维修社区 - 创建账户
Kenmore 品牌 Kenmore 80 Series 洗衣机的维修指南。
F7 E1 code keeps coming up
F7 E1 code keeps coming on. Washer will quit at various times, and often times won't even start. Lid lock light will flash at end of some cycles and I'll have to restart cycle. In test mode it works fine. Put clothes in and troubles start
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Please give us your model number.
The F7 E1 error code indicates a Basket Speed Sensor Fault in the top-load, belt-drive washer (VMW). F7 E1 is displayed when the main control cannot determine the speed of basket—or speed changes too quickly. The first component to check would be the speed sensor circuit in the shifter, which if not functioning, will generate the F7 E1 error code. However, there are several other potential causes that might also prevent the basket from moving (e.g., calibration, friction, or one of the drive system components, among others) that may also generate this error code.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
johnjohn225867 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 3,937
