Why wont my phone charge?
I dropped my phone and it will not charge after the drop. When plugged in, it turns on and off on a cycle and the battery logo comes on. It will show the logo for a few seconds and then continue on a loop.
Cesar Ramos the looping can be an issue with the battery/power. Check to make sure that the battery is still fully seated and that it makes proper contact and that the battery flex is not tore. You will have to do a bit of disassembly for that. In your phone case and if this still the original battery, I would replace it at the same time. HTC One M8 更换电池
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 49
