跳转到主内容
加入维修社区 - 创建账户
TI-84 Plus CSE 是德州仪器 (Texas Instruments) 于 2014 年发布的一款图形计算器。它是 TI-84 系列中首款配备彩色屏幕的计算器。
"Waiting... Please Install Operating System Now"
My calculator says "Waiting... Please Install Operating System Now", and when pressing any button it says “Error! Press any key to turn unit off. Then turn unit back on”, then the process just repeats itself. I have tried to restart the calculator but it did not work. I also tried to download an OS from the TI website from my Mac to the calculator but it also did not work. I believe it said something along the lines of it wouldn’t download the operating system to the calculator because the calculator didn’t have OS, which was kinda the whole point of trying to download it! I also could have done it wrong though, so any help would be appreciated on how to get my calculator working again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
@annaelk Hi, I'm very sorry I'm so late to this. While I come up with an answer, could you please tell me what OS version you're trying to send over? (Does the file name have 4.2 somewhere in it?) Also, what happens if you connect the calculator to the computer, open TI Connect CE, go to 'actions' then click 'send OS/ bundle to calculator' then select the OS you want to send? Lastly, what were you doing just before it broke? (Is there water damage, did you accidentally drop it?)
由完成的 分享
添加一条评论
5个答案
最有帮助的答案
Hi, it sounds like your calculator is still functioning, you may have misunderstood how to send over the OS. Here’s a tutorial for the TI 84 Plus CE: TI-84 Plus CE 恢复方法
Although it’s a different model, the steps are very similar. The only difference is you need to send over OS 4.2 which you can find here: https://tiplanet.org/forum/archives_voir... I think your problem may have been you tried to send over the incorrect OS because I couldn’t find a compatible version for your calculator on TI’s website. Where did you happen to find your copy?
Your calculator should be working again. If it’s not, I may have something else you can try to fix it!
这个答案有帮助吗?
得分 4
2条评论:
Bruh that's a TI-84 CE. This is for a TI-84 Plus C silver edition.
由完成的 分享
@corbanizer The steps are almost exactly the same. I noted the few differences in my answer. Is something not working for you?
由完成的 分享
添加一条评论
Get Ti-connect, plug the calculator in, then go to software. Select check for updates and it should said it needs to be updated. Then select update and wait for the installation to be done.
这个答案有帮助吗?
得分 1
1条评论:
There are two Ti calculator programs. Get the older one.
由完成的 分享
添加一条评论
You need to haveTI-Connect CE, go to OS LINK then download it, connect your calculator, then send the files and your done.
这个答案有帮助吗?
得分 0
添加一条评论
still not working! I tried all the steps.
这个答案有帮助吗?
得分 0
添加一条评论
install OS TI84Plus_OS255.8Xu. NOT TI84Plus_OS222.8xu
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anna Elk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 39
总计 11,703
