跳转到主内容
This laptop was released in late 2015 and came running Windows 10 Home. It features a touch screen display, Intel i5 processor, and a 1 TB hard drive.
3 个问题 查看全部
seems to have a defective power port.
It seems the power port is defective. I have tested the charger on another laptop and purchased a new battery that works, so have to assume it’s the port. Is it part of the motherboard or a separate item?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @edwardw10 ,
Here’s a link to the hardware maintenance manual for a HP Pavilion 15-ab243cl laptop, taken from this webpage
Scroll to p.69 to view the necessary pre-requisite steps and then the procedure to remove / replace the Power connector cable.
Disconnect the cable from the motherboard and then use an Ohmmeter to check the wires for continuity from the socket through to the cable connector plug.
If it is determined that the cable is faulty then you’ll find the spare part numbers at the top of the same page in the manual.
Search online using the part number only to find suppliers of the part.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edward Wilman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 134
