跳转到主内容
加入维修社区 - 创建账户
Maytag 洗衣机型号 MVWB765FW 是一款带有深水填充选项的波轮式洗衣机。该洗衣机的容量为 4.7 立方英尺。
Error code F5 E1
Maytag bravos xl top load washer has error code F5 E5
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
@sharon1 your error code is a F5 E1 or F5 E5 your question does not make it clear :-)
由完成的
hi thire this washer its flashing e5 what is the worring
由完成的
添加一条评论
2个答案
最有帮助的答案
Hi @sharon1,
According to this link, a F5 E1 error code is a lid lock fault.
This is the quote from the page regarding the error code.
F5 E1
Lid switch fault
Check/Repair
This code is displayed if Start is pressed with the lid open. If the lid switch on the lid lock/switch assembly isn't detecting the condition of the washer lid properly, then the lid lock/switch assembly will need to be replaced
This is assuming that I’ve linked the correct page for your particular model that is.
Try disconnecting the power from the washer for about 10 minutes and check if the code is still there when you reconnect the power and go to use the washer.
What is the full model number of the washer so that the code meaning can be verified and the correct parts be located?
这个答案有帮助吗?
得分 4
2条评论:
MVWB765FC maytag top load
由完成的
Hi @ melody reyes
There are 4 model variants for the model number you posted.
Here's a link to the C1 model. The lid lock is part #14 shown in the Top and cabinet parts diagram. Scroll through and click on it to view the location etc.
由完成的
添加一条评论
This means your lid can't lock and you may hear a constant clicking sound. I had to repair one of these for a friend and it's attributed to a poorly designed position sensor for the lid lock. The contacts were dirty and the controller was unable to determine the position of the lock.
I had to remove the top of the washing machine and unscrew the locking mechanism from underneath the top cover. Once I had the locking mechanism out, I disassembled the housing and pulled the circuit board out, paying attention to the orientation of the sliding contact. I cleaned all points of contact with deoxit and added some fresh dielectric grease, reassembled everything and voila!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sharon Fedrick 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 38
总计 12,235
