跳转到主内容
加入维修社区 - 创建账户
这是一系列帮助修理洗衣机的指南和支持。
Amana won't complete a cycle.
My Amana won't complete a cycle. I have to start on normal then once that stops, I have to turn the dial to rinse/spin then once that stops, I have to turn it again to drain/spin. It is a brand new Washer. Still confused on why it does this. This is my replacement for the first one I had that did the same thing. Can anyone give me any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Hi,
What is the model number of the washer?
完成的
My machine is only 3 years old and it will only go through the wash cycle and not rinse and go any further. Does anyone have any suggestions as to what it might be. I called Aaron's where I bought it and was told that since it's been paid off they can't send anyone to come look at it so now I'm stuck with a washer that won't go into the rinse cycle and finish washing?. I live on a fixed income and can't afford to buy another washer.
完成的
Hi @Robyn Bomba
完成的
I have an Amana and it washes fine but when it starts to fill up to rinse it stops drains an doesn't spin out completely so then I turn it drain /spin
完成的
Same issue. At first I thought it was me Whew
完成的
添加一条评论
1个答案
已选择的解决方案
jessmaddox0726  since this is a brand new washer, I would recommend to not do anything about it from a DIY perspective just now. Call the vendor you bought it from and inform them of what is going on with your washer. Have them fix it for you since it will be their obligation to do so. Hold them accountable for this. Let us know how it works out so we can at least try and support you with this issue.
这个答案有帮助吗?
得分 1
11条评论:
I alway take out an extended warranty on anything I have problems with during the first year.
完成的
I have the same washer doing same $@$* to me
完成的
Brand new ! Just opend the box today
完成的
Also having the same problem, never again will I buy an amana
完成的
Had to get this at the beginning of the pandemic. Has done this from load one. I worked for Sears for years. This is the worst washer I have owned in all 45 years of doing laundry. I feel Amana needs to recall these and replace them. I'm on disability. This isn't even funny!
完成的
显示更多的6条评论
添加一条评论
添加你的答案
jessmaddox0726 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 36
总计 7,700
