Screen not rotating when device turned
Suddenly my screen won't change from portrait mode to landscape when I turn the device - only showing in portrait even when turned sideways
Update
Thank you, nicksmacandpchelp and oldturkey03! Got it! :)
On the side, like the iPhone, only the iPad's locks the rotation, reset that to unlocked and that should do it
这个答案有帮助吗?
I have noticed this problem too while using some apps like SKYPE on the IPAD2. When ever an app like SKYPE is crashed or closed. The screen tilting is not working. I think if you restart the device, this is not repeating. This may partly answer your question. But this is what i have identified so far.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,326
2条评论
Try turning device off then powering on, may need just to reset itself
由 pollytintop 完成的
Isn't there a switch by the volume that locks it into place? Have you checked on that and make sure it is properly set.
由 oldturkey03 完成的
