跳转到主内容
The RCX 1.0 is the first model in the RCX line of Lego Mindstorms programmable bricks.
3 个问题 查看全部
How to fix RCX 1.0 I.R. problem?
The LEGO RCX 1.0 powers ON and all built-in programs work well. But when I tried downloading or even communicating with the I.R. Tower, the RCX wont respond! =(
Which component should be replaced or re-soldered? Please anyone... help pls. I just need to know.. which hardware component is at fault... so I can fix it.
Thank you =)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
hello, i have the same problem like sirgilberts.
My RCX 2.0 shows a icon for IR detection and my older RXC 1.0 doesnt react - i have three of them but they wont work.
完成的
I'm working in a Schoolboard and i have 6 RCX 1.0 bricks with the same problem. I am interested if someone finds a solution.
完成的
添加一条评论
1个答案
已选择的解决方案
http://www.squidoo.com/collected-info-on...
it sounds like it may be a software problem, make sure you're up to date with any drivers for your console
这个答案有帮助吗?
得分 1
1条评论:
also take a look on here http://messageboards.lego.com/en-US/show... for some more ideas.
完成的
添加一条评论
添加你的答案
sirgilberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,725
