跳转到主内容
The RCX 1.0 is the first model in the RCX line of Lego Mindstorms programmable bricks.
How to fix RCX 1.0 I.R. problem?
The LEGO RCX 1.0 powers ON and all built-in programs work well. But when I tried downloading or even communicating with the I.R. Tower, the RCX wont respond! =(
Which component should be replaced or re-soldered? Please anyone... help pls. I just need to know.. which hardware component is at fault... so I can fix it.
Thank you =)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
hello, i have the same problem like sirgilberts.
My RCX 2.0 shows a icon for IR detection and my older RXC 1.0 doesnt react - i have three of them but they wont work.
完成的
I'm working in a Schoolboard and i have 6 RCX 1.0 bricks with the same problem. I am interested if someone finds a solution.
完成的
The main problem is that Windows does not recognize the IR tower. This happens with versions newer than XP.
完成的
添加一条评论
1个答案
已选择的解决方案
http://www.squidoo.com/collected-info-on...
it sounds like it may be a software problem, make sure you're up to date with any drivers for your console
这个答案有帮助吗?
得分 1
1条评论:
also take a look on here http://messageboards.lego.com/en-US/show... for some more ideas.
完成的
添加一条评论
添加你的答案
sirgilberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 23
总计 2,977
