跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
What parts do I need to make my MacBook run like new?
I know I need to replace the battery, but should I upgrade my RAM or anything else to make this laptop run like new?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
[image|2212618] @mayer
完成的
添加一条评论
1个答案
已选择的解决方案
This machine is a real keeper and well worth upgrading.
To get it to run better than new:
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Replaced the hard drive/IR cable with a new one and add damage protection
MacBook Pro 13" Unibody 中期2012 硬盘线缆替换
install a backward compatible SSD like the Samsung 860 EVO or QVO 1TB or 500 GB
the Crucial drive will also work
Crucial MX500 500 GB SSD
max the RAM out at 16 GB
MacBook Pro 13" Unibody (Mid 2012) Memory Maxxer RAM Upgrade Kit
MacBook Pro 13" Unibody 中期 2012 RAM内存条更换。
Crucial MX500 500 GB SSD图片
产品
$41.99
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable图片
产品
$34.99
MacBook Pro 13" Unibody (Mid 2012) Memory Maxxer RAM Upgrade Kit图片
产品
$89.99
MacBook Pro 13" Unibody Mid 2012 RAM 内存条图片
指南
难度:
简单
15 - 30 minutes
MacBook Pro 13" Unibody Mid 2012 硬盘线缆图片
指南
难度:
简单
10 - 25 minutes
这个答案有帮助吗?
得分 5
3条评论:
Wow, thank you so much! I thought I'd have to buy a new laptop from Apple. Good to know that I can make this run way better!
完成的
This is the last of the really repairable, upgradable MacBook pros and was produced through 2016 because of demand, so it will probably continue to even be supported by Apple (but I wouldn't count on it). The upgrades really kick this machine up so they are still very competitive with the newer models. They are also very repairable and a broken display won't break the bank like a retina will.
完成的
@mayer I appreciate all the help, I’m actually just now getting around to upgrading with these parts, but I noticed something peculiar.
Around the airport/Bluetooth cable there’s some corrosion that I know nothing about. Should I replace it?
完成的
添加一条评论
添加你的答案
Tyler Clincher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 73
