Battery Replacement with 2 pin
I bought a li po battery with only 2 pins on it instead of 3. Can I still use this? Based on my research i can use a 10k fixed resistor. Anyone know how I can do that? Any help will be much appreciated.
Hi!
Yes you can probably get it working with a 2 pins battery, but I wouldn’t do it.
Just return the battery and get yourself the correct one that is supposed to work with your Corsair Void Pro RGB, it will spare you some trouble too.
这个答案有帮助吗?
Thank you for the input but your suggestion is not possible for me due to logistics on acquiring the battery
Okay. Do you have a picture of the battery you bought and a picture of the original battery ? Thanks in advance!
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 413
