跳转到主内容
加入维修社区 - 创建账户
一款带有 USB 2.0 和 Firewire 400/800 接口的外部硬盘。容量从 320 GB 到 2 TB 不等。
Data Recovery Issues after restore
Hello everyone.
I have a western digital which I had stored videos from my macbook pro using the software final cut pro.
About a week back the hard drive crashed and I took the external hard drive and attached it to a PC running windows 7 and ran a recovery program called EASEUS recovery. I was successful recovering the the videos , but I can't play the videos neither on a mac or pc. Keep getting an error that the file is invalid. Is there a special software or a particular way to run recovery which would enable me to recover the videos properly.
All help is appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi can i suggest that you check one if the files info and comfirm if the size of the file tally with what you have?
由完成的 分享
添加一条评论
3个答案
已选择的解决方案
I would contact the maker of the software you used for assistance. They probably used a file system locked to their software and should be able to tell you how to make it readable again. If they can't help you I would contact WD for help. Save the drive -- you may need to recover again.
这个答案有帮助吗?
得分 3
添加一条评论
Use free tool called Disk Drill, to recover your deleted videos. It's very important to preview your files before recovering. http://download.cnet.com/Disk-Drill/3000...
这个答案有帮助吗?
得分 1
添加一条评论
If you can not open the video, that means the video was not recovered completely. Try other better video recovery program like Card Data Recovery.
这个答案有帮助吗?
得分 0
2条评论:
hello,
Ok the issue is the data was lost on a mac and the recovery was done using a windows pc that is the reason the files seem to be corrupted. Is there a software or solution to convert it back to mac format.. thanks
由完成的 分享
Probably not, because you now have a corrupt file structure, It can not simply be fixed by converting to mac format.
由完成的 分享
添加一条评论
添加你的答案
cyrus s 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 3,740
