跳转到主内容
加入维修社区 - 创建账户
Kia Optima 是起亚汽车(Kia Motors)自 2000 年起生产的一款中型轿车,在全球范围内以多种名称销售。第一代车型(2001-2005 年)通常被称为 Optima,不过从 2002 年起在欧洲和加拿大开始销售时,该车型的名称为 Kia Magentis。
My door won't open
My driver's side door is shut and will not open. How do I get the door panel off?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
It does not open with the outside or the inside door handle? Does your lock work? Do you have power lock's?
由完成的
our car is having the same problem. local mechanic cannot fix until he gets door panel off which he cannot do because door won't open. Locks work fine. any suggestions???? will not open from inside or outside
由完成的
添加一条评论
2个答案
最有帮助的答案
Check on here and look for an answer by ekubec. Here is a further link that gives you more details as well as pictures. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
hello:
Simply order a new door latch assembly for the door with problem (mostly drivers side door) thru ebay, Amazon or Partsgeek and have them deliver to you ( about $55 delivered), take to an auto service shop and they will install that for $65. After that it will work great. Door problems are due to wear and tear and latch assemblies fail and need replacement. This is a maintenance problem, like changing water pump or any other part of the car. I don't think any other way of fixing will work.
Kumar
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chadda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 7,627
