跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
HHD to SSD Upgrade in 27" iMac question
I have the “Crucial MX500 2TB 3D NAND SATA 2.5 Inch Internal SSD” and would like to put it in my Apple iMac 27-Inch "Core i5" 3.4 (Identifiers: Late 2013 - ME089LL/A - iMac14,2 - A1419 - 2639). I’ve been reading a lot about how to do this and have a few questions.
  1. What is the thermal sensor and is there one that I need to use specifically with the Crucial SSD?
  2. Is there a special adhesive to use that won’t have issues in the future of the screen falling off? (This scares me the most)
  3. Some people say that the bracket that comes with the Crucial SSD doesn’t work, is that the case or do I need to get another bracket to hold the new SSD in place?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here’s how to convert it to a 2.5” SSDS. Use the adhesive strips:
iMac 因特尔 27" EMC 2639 硬盘更换
UPDATE
Sometimes you really have to look at all the information in the guide.
1. Thermal Sensor https://eshop.macsales.com/item/OWC/DIDI...
2. Adhesive strips: [关联产品丢失或禁用: IF174-005]
3. You just need a 3.5” to 2.5” adapter. It does not have to be a fancy one or need a plug in. The OWC adapter plugs right into it.
这个答案有帮助吗?
得分 2
1条评论:
Thank you I read this thoroughly including the comments people posted before posting my question here since it still left me with questions
完成的
添加一条评论
添加你的答案
tobedor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 159
