跳转到主内容
加入维修社区 - 创建账户
针对第三代 Apple iPad (Wi-Fi 版) 的维修指南、拆解和故障排除信息,存储容量有 16 GB、32 GB 或 64 GB 可选。于 2012 年 3 月发布。型号为 A1416。维修时需要使用加热设备并小心撬开。
Ipad screen gone black
A couple days ago I dropped my ipad about 2 inches high onto my leg. the screen went black. I tried the rebooting sequence but it doesn’t help. Power still gets to it, as went it is turned on, you can see a slight but almost unnoticeable change in the brightness of the black but you have to be in the dark to notice it. Now would it be the screen gone bad or the display driver?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try shine a bright light to the screen at boot or when toggling power button to check if you have a dimmed out image or no image at all. In first scenario there’s a higher chance of a board backlight issue whereas in the second an Lcd failure would be more likely. Yet, we are just talking about probabilities, without known good parts or tests one can never be 100% sure.
这个答案有帮助吗?
得分 3
2条评论:
Did try shining a light on the LCD display. It was still completely black.
完成的
@johntanguay An Lcd replacement would be the most reasonable first step then.
完成的
添加一条评论
添加你的答案
John Tanguay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 347
