跳转到主内容
please identify resistor on the powerboard
Machine could not be switched on. Replaced the logic board battery, reset the PMU, did all the other tricks recommended on this site. Took the machine to pieces, got to the power board, removed the obviously faulty resistor. Having trouble identifying it since the colour bands are hard to make out, could be a browny green or a greeny brown. It could be 12 Ohms or a smaller number. Does anyone on here know the likely value of this resistor?
ETA: the colours are clear in daylight, not sure which sequence is correct though
Resistor
Powerboard
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
A picture would be useful as there are a few resistors and capacitors on the power board 在已经存在的问题里加入图片
完成的
@Folake Shoga - Really need to know where on the board it came from.
完成的
Thanks guys. I’ll post again after we’ve tried the fix
完成的
添加一条评论
1个答案
最有帮助的答案
Folake Shoga  that looks like a 1K ohm resistor
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Folake Shoga 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 95
