跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
Where is complete Disassembly Guide
Hi
I can't seem to find the complete disassembly guide for model A1286 - only the initial teardown...does it exist?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
I have a couple of the MacBook Pro's service manual but need to have at least the year for your model to see if I can help you.
完成的
"Complete Disassembly" isn't really a term we use around here. Depending on your specific model and needs, we can try to point you towards the correct repair guide.
完成的
There are 16 models in the A1286 series. If you can give us the last three figures of your serial number we can direct you to the proper guides that are available.
完成的
Hi
Thanks for the replies - model late 2008 -serial no. ends in Q1G0.
Thanks
完成的
THank you very much indeed for the tech manual.
regards
al
完成的
显示更多的2条评论
添加一条评论
2个答案
Apple MacBook Pro "Core 2 Duo" 2.4 15" (Unibody) Specs
Identifiers: Late 2008/Unibody - MB470LL/A - MacBookPro5,1 - A1286 - 2255
The machine I put up is a late 2008 and should be your machine. Just take a look at the guides for confirmation.
MacBook Pro 15" Unibody Late 2008 & Early 2009
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
May be this will help
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
al davies 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,528
