跳转到主内容
加入维修社区 - 创建账户
一种向耳朵传送低频音频的通用音频设备。
Only 1 amp working!
I have 2 amps set up everything is wired up good I checked all my volts with a multimeter ,and everything checks out . But it seems that I can only have 1 amp wired to get any power . I wired each of my amps to 1 power source and each amp started up so is there a reason I can’t set up my highs amp and my bass amp ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@jaimeibarra what make and model are your amps. How did you wire them up? Schematic or picture?
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
There might be an issue with the remote turn-on lead. Some radios don’t provide enough current out of the remote lead to turn on multiple amps. Try running 12V from the battery to both of the amps remote turn-on leads and see if they both turn on. If that works, then you can use a relay connected to the radio’s remote turn-on lead and switched 12V power to switch your amps on. Also check to see if you get a voltage drop when both amps turn on at once. It’s possible that one of the amps is going into protection mode due to under-voltage. There could be a wiring, car battery, or alternator problem that isn’t supplying enough current for all your car’s electronics.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jaime Ibarra 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 23
总计 453
