跳转到主内容
加入维修社区 - 创建账户
Dell Chromebook 11-3120 是一款价格实惠、轻便的笔记本电脑,多用于专业办公和教育环境。
Powering off while typing
I have a student who’s Chromebook is automatically powering down while the student is typing. Any suggestions would be greatly appreciated?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论:
Hi Justin, if i understand, if you start typing, the battery % will go fastly down? Or just your power supply will disconnect?
由完成的 分享
Just power off.
由完成的 分享
Hi Justin,
just last question, if the HDD is not connected and you are booted into the BIOS if you start the randomly typing on your keyboard, is the laptop still shutting down?
由完成的 分享
It is not shutting down as of right now.
由完成的 分享
Hi Justin,
so if it's not turning off after the HDD is unpluged, the HDD is damaged or the sata interface on the MB is damaged. The same situation you can create "in the laboratory" by hitting laptop into the touchpad or keyboard very hard. Then your system will crash and laptop will shut down... Try to exchange the HDD and if it's now OK, then is damaged. If not, try to analyse the SATA slot.
由完成的 分享
显示更多的2条评论
添加一条评论
3个答案
I would start by performing a power wash on the device. If its a school device the student would have to contact their tech department to do this because its a managed device that requires enrollment credentials.
这个答案有帮助吗?
得分 0
2条评论:
I am the tech dept. I tried power washing and disconnecting the battery. The student has not came back with any problems for awhile.
由完成的 分享
Oh ok, awesome, Sorry I didn't know if you where a teacher or something else :) Hopefully, they don't. Ive had a few boards with bad soldering so maybe the pressure of the student typing is testing and shorting out so it powers off. Chromebook boards are made super cheaply especially in education
由完成的 分享
添加一条评论
this happens commonly !!! its a screw that is loose and rolling around in the chromebook and it is where the chromebook magnet is to turn it off and the dell screws are like magnets so the will shut off the chromebook (just take off bottom and look by the charger port for a loose screw!!!!
这个答案有帮助吗?
得分 0
添加一条评论
You can run the Power troubleshooter to adjust your computer's power settings. The Power troubleshooter checks things like your computer's timeout settings, which determine how long the computer waits before turning off the monitor display or entering sleep mode.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Justin Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 28
总计 1,894
