跳转到主内容
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Charging port broken, how to replace it?
In short, title
a few months ago the charger on my Asus x555L started acting strangely, only charging when it was turned at a certain angle. now it refuses to charge entirely, and the charger will not stay secure in the port as the port is broken. how would I replace the port with a new one, thereby fixing the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
The charger port is soldered onto the board meaning you’d need either a hot air rework station + soldering station to remove the port or a soldering iron station + solder sucker to remove the old solder to remove the old charger port.
A lot of the time these ports can actually be repaired without replacing by redoing the solder on these ports as seen in this video:
https://www.youtube.com/watch?v=qWXISqQh...
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
stan_albatross 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 1,264
