跳转到主内容
加入维修社区 - 创建账户
与AirPort Extreme基站一起发布,这款配备硬盘的Time Capsule NAS提供802.11ac速度。
Max Hard Drive size
Hello. I’m going to replace the internal hard drive on my Time Capsule A1470. I’m wondering if one 10 TB or 12 TB WD RED PLUS would fit. Does anyone know what’s the maximun drive size supported by the AirPort Time Capsule A1470?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
添加一条评论
3个答案
已选择的解决方案
I’m not sure what the maximum is, but I upgraded the hard disk on my Time Capsule to a Seagate 14TB disk and it works without a hitch. No software or formatting conflicts. So your 10 or 12 TB disks should work fine. The only drawback I have found is the bigger disks can be a little noisier when writing (mine certainly is), but that I can live with.
这个答案有帮助吗?
得分 9
添加一条评论
I think you’re going to run into power issues as these larger drives pull more power, while it might work for awhile the power supply will overheat and fail. Also these drives putout more heat as well.
Look up the specs of your current drive and make sure whatever drive you go with does not exceed the current draw.
Frankly, I would go with a SSD instead. You don’t need the fastest drive, a cheaper SATA II drive will be just fine!
这个答案有帮助吗?
得分 5
3条评论:
I would NOT recommend SSD drives to time capsule. This is because backups will be made daily, so there will be lots of writes, and SSD life will be very short (SSD drives have limited write life). For this type of application, a good quality NAS magnetic drive will be better.
由完成的 分享
@danimir The TBW issue hasn't been as bad in recent years. As long as you get a good drive, you can get one that will easily last 300TBW+. It's the cheap drives (usually they tend to be 75TBW, even today) and legacy 75TBW drives from a few years ago you have issues with.
由完成的 分享
@Nick Which SSD would you propose in 2023? I'll be getting the TC in about a month and I want to get an SSD as opposed to a HDD. I presume the SSD runs cooler. My main use for the TC is a media server not even as a backup.
由完成的 分享
添加一条评论
I've successfully upgraded my time capsule to 16TB in 2021 using Seagate EXOS 16TB drive. It works without a hitch for about 2 years now.
As this is a bit older hardware, I was doubtful that the hardware could support more than 16TB, this is why I've decided not to go any higher.
这个答案有帮助吗?
得分 3
1条评论:
this is mighty encouraging to hear. I'm guessing the Seagate EXOS is the same size as the original Baraccuda so you didn't have to customize the rubber mountings? Also I've been seeing comments about a preference of CMR over SMR. I'm planning to use mine as a media storage for my media server will this work?
由完成的 分享
添加一条评论
添加你的答案
Marco Pusceddu 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 89
总计 10,208
