跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
Can I use a hard drive from another MacBook Pro in this machine
I have a Macbook Pro early 2009 with replaceable battery. It has broken down.
My solution was to buy a used Macbook Pro 2.53 Ghz, mid 2009.
The hard drive from the broken down computer has Yosemite installed as the OS. The 2.53 Ghz machine has El Capitan installed as the OS.
I want to preserve some software with features in iTunes that are no longer available. There are other configuration settings I want to preserve as well.
I want to replace the hard drive in the 2.53Ghz machine with the hard drive from the broken down machine. Can I do this? I noticed from hard drive replacement for the 2.53 Ghz machine on iFixit that the hard drive is mounted in the same bracket as the optical drive. It is listed as dual hard drive.
Thank you for time and attention;
JK
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
I found the hard drive replacement guide for the Macbook Pro 2.53 Ghz
machine.
It is essentially the same as replacement for the early 2009 machine
accept that the built in battery is a bit more complicated than removing the removable battery.
So what is the hard drive in the optical drive enclosure for?
完成的
Why would you remove the battery?
完成的
Battery removal is part to replacing the hard drive according to the
replacement guide instructions. Is that not necessary?
Thank you for time and responses
完成的
No, do not remove the battery, you can disconnect it but removal is not needed.
完成的
添加一条评论
2个答案
已选择的解决方案
You can surely set up a dual drive if that’s what you’re asking for, but you’ll have to remove your optical drive and buy an enclosure/adapter for that purpose to be able to run both hard disks at the same time. Consider the optical drive port is slower than the Sata port normally used for hard drives. If instead all you need is to transfer your drive from one Mac to another you’ll just have to loosen a couple of screws on each Mac to replace and swap drives.
Yosemite can be updated to El Capitan any time you want without losing any files or settings. On the Apple store you should be presented with the possibility to download 10.11 at will.
这个答案有帮助吗?
得分 2
添加一条评论
I did it:
I installed the hard drive with Yosemite in place of the
hard drive with El Capitan.
Everything appears to be working as expected. I now
have the hard drive with El Capitan in the USB adapter
case. So I don’t need to install a second drive. I have
two other machines with High Sierra. I like to spread
processing and storage load over different machines.
Thank you all for responses
JK
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jekillen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 104
