跳转到主内容
Portable Bluetooth speaker released in June 2015. The speaker features ClearAudio+ Technology and LDAC Technology. Model Number: SRS-X55.
9 个问题 查看全部
My adapter is broken on my speaker
The yellow part where you charge the Sony SRS-X55 is broken. How can I replace this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Darla Dang that is your DC in jack. It is soldered to the I/O board. Remove that board by using this guide Then check if you can unsolder it and find a replacement based on the dimension from places like mouser. com or digikey.com etc. Not a terrible complicated repair but it does require some soldering skills.
You can get the jack connectors from here https://ru.aliexpress.com/item/202656625...
这个答案有帮助吗?
得分 1
添加一条评论
The port the charger goes in the pin has come off the male component that's inside the speaker so I think I need a new connector so then I can charge as normal cheers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darla Dang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 455
