跳转到主内容
Sony SRS-X55 I/O Board Replacement
你所需要的
  1. Sony SRS-X55 I/O Board Replacement, Battery: 步骤 1 中的图像 1,3 Sony SRS-X55 I/O Board Replacement, Battery: 步骤 1 中的图像 2,3 Sony SRS-X55 I/O Board Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 I/O Board Replacement: 步骤 2 中的图像 1,1
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 I/O Board Replacement, I/O Board: 步骤 3 中的图像 1,2 Sony SRS-X55 I/O Board Replacement, I/O Board: 步骤 3 中的图像 2,2
    • Remove the two Phillips screws from the I/O board.
    • Remove the front panel to the speaker by pushing on the two tabs in the corners.
  4. Sony SRS-X55 I/O Board Replacement: 步骤 4 中的图像 1,1
    • Disconnect the ribbon cable from the I/O board.
    • Carefully remove the I/O board from the speaker.
结论
另外一个人完成了本指南。
一条评论
Where can i get a new i/o board?
Kyle Workman - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 22
总计 2,394
