跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 个问题 查看全部
My screen is all white.
It can be charged and turned on and off. However, it stays at a fully white screen. I have already tried pressing the reset button behind but it just turns the screen off. I spilled a tiny bit of water on it yesterday and discovered it today. Is it water damage?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This does sound like water damage so immediately stop charging the calculator and remove the battery! That way you can avoid accidentally shorting out the calculator and permanently breaking it (I’m hoping that white screen is a software error that can be fixed later). Remove the back cover of the calculator using the teardown guide and dry off the PCB as best you can (make sure to get underneath the aluminum foil). If your calculator isn’t under warranty, then you can go ahead and break the heat melted bits holding the PCB to the front shell. That way you can make sure the front of the PCB, the rubber membrane, and all the buttons are dry.
I’m not an expert at water damage so I would appreciate some guidance from the iFixit community for the following steps.
(As I said above, I’m no expert so this next step may be unnecessary, but it won’t hurt the calculator to do it anyways) From there you should clean everything with at minimum 91% isopropyl alcohol (aka rubbing alcohol) (higher percents are better). Then you should stick everything in rice for several days so any water has time to evaporate. After several days, you can take everything out and just to be safe, clean it all again with the isopropyl alcohol.
Once you’ve put everything back together (let me know if you need help with that), then you can put the battery back in and try to turn it on. If you still get a white screen, try some TI-84 Plus CE Recovery Techniques. If it still doesn’t work properly even after trying that guide, let me know and I’ll have you try some troubleshooting techniques to see if it’s hardware damage.
TI-84 Plus CE Battery图片
指南
Texas Instruments TI-84 Plus CE Battery Replacement
难度:
简单
1 - 5 minutes
TI-84 Plus CE图片
指南
难度:
简单
5 seconds - 10 minutes
TI-84 Plus CE图片
指南
TI-84 Plus CE Teardown
难度:
中等
40 minutes
这个答案有帮助吗?
得分 0
1条评论:
Hi Lastmillenial saw this post of yours and I seem to have the same problem with my son’s caculator. I ran through the steps you already provided but no luck, still a white screen b.o. water damage. Is there a way to determine if it’s a hardware issue? Thanks a lot from the Netherlands ?
完成的
添加一条评论
添加你的答案
kaster hood 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 41
总计 1,106
