跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的TI-84 Plus CE,应参考我们的维修指南
  1. TI-84 Plus CE Teardown, Remove the battery.: 步骤 1 中的图像 1,3 TI-84 Plus CE Teardown, Remove the battery.: 步骤 1 中的图像 2,3 TI-84 Plus CE Teardown, Remove the battery.: 步骤 1 中的图像 3,3
    • Remove the slide cover.
    • Turn the calculator so the screen faces down.
    • Take the Phillips #0 screwdriver and remove the battery cover.
    • Remove the battery. (You may need to use the spudger)
    • Warning: your calculator's RAM will be cleared!
    • Information stored in the Archive will be safe.
  2. TI-84 Plus CE Teardown, Removing the screws: 步骤 2 中的图像 1,2 TI-84 Plus CE Teardown, Removing the screws: 步骤 2 中的图像 2,2
    • Use the Phillips #00 screwdriver to remove the screws underneath the battery.
    • Use the T6 screwdriver to remove the 6 screws on the edges of the calculator.
  3. TI-84 Plus CE Teardown, Separating the shells: 步骤 3 中的图像 1,2 TI-84 Plus CE Teardown, Separating the shells: 步骤 3 中的图像 2,2
    • Use a spudger to separate the top shell from the bottom one by prying the crease all around the calculator.
    • The screen bezel separates easiest.
    • You do NOT need to worry about keeping one side face down. The buttons will not fall out.
    • The middle part is very difficult to separate! You will need to use a lot of force.
    • You do NOT need to worry about tearing any cables.
  4. TI-84 Plus CE Teardown, The Reset button: 步骤 4 中的图像 1,2 TI-84 Plus CE Teardown, The Reset button: 步骤 4 中的图像 2,2
    • With the back shell off, you can now access the Reset button.
    • Take off the white and black rubber to access the hard plastic part.
    • These are two separate pieces.
  5. TI-84 Plus CE Teardown, Accessing the LCD: 步骤 5 中的图像 1,2 TI-84 Plus CE Teardown, Accessing the LCD: 步骤 5 中的图像 2,2
    • Gently bend back the Aluminum shield. You will not be able to take all of it off since it is partially glued on.
    • There is some shielding wrapped around the LCD.
    • If you need to access the LCD, you can pick it up and bend it back.
    • Be careful not to rip the tan ribbon cable. (Which is removable)
    • Follow this guide to safely disconnect the ribbon cable from the ZIF connector: 认识和断开线缆连接头
    • With the LCD out, you can now easily pop out the transparent, plastic cover that's connected to the shell. This allows you to replace the glue if it's weak.
  6. TI-84 Plus CE Teardown, Details & Final thoughts.: 步骤 6 中的图像 1,3 TI-84 Plus CE Teardown, Details & Final thoughts.: 步骤 6 中的图像 2,3 TI-84 Plus CE Teardown, Details & Final thoughts.: 步骤 6 中的图像 3,3
    • Here are high resolution images of the front of the PCB and back of the PCB.
    • Here you can see all the components of the Motherboard. Unfortunately, all the components on the PCB (except the LCD ribbon cable) are all soldered onto the motherboard.
    • Unfortunately, to access the buttons underneath the motherboard you will need to break the melted bits on the PCB because it is heat-melted to the shell.
    • Be sure to keep the buttons facing down otherwise they may fall out.
    • Once the PCB is removed, you can now remove the grey membrane to reveal the buttons.
    • I thought I'd give this an unofficial repairability score. I give it a 4. The battery is trivial to replace. The shell is (mostly) easy to remove, the LCD screen, LCD plastic cover, and the Reset button can be replaced. However, you can not upgrade anything, nor easily replace the FLASH, ASIC, USB, LED, keypad buttons and battery contacts.
TheLastMillennial
于07/18/18注册
3,552 声望
创作了2篇指南
29条评论
This brings up a memory of mine. When I was in the 5th grade, they had just released the TI-89. In school we were asked to buy the TI-83 Plus. I remember fondly buying the TI-89 by accident not realizing it was actually a different model entirely (it has a built-in computer algebra system among other things). I had always enjoyed technology and figuring how things worked so I read the entire manual and tore the calculator up seeing all the specs. Of course when it came to testing time, we were only permitted to using the TI-83 Plus. Using the TI-89 was basically cheating, but I had no idea how to use the TI-83, and they actually checked that you were using a compliant calculator. I found that I could transplant the entire guts on the TI-89 into the TI-83 Plus. I didn’t matter that none of the buttons were the same. I had memorized every function in the calculator. No worries, I only used the functions permitted. I was a good student after all.
ranron - 回复
Are you sure it was the 83 Plus you transferred the internals to or was it the 84 Plus? The 84 Plus uses the same shell design as the 89 and I've never heard of fitting the 89’s internals into an 83 Plus! That's not saying it's impossible though, cool story!
TheLastMillennial -
just for exploring all this you should have passed the test!
boddeke -
Does anyone know where to get replacement parts? other forums have said to just buy another calculator but the 200$ price tag is not very encouraging.
Evan Kaba - 回复
@evankaba Well the goal is to buy a cheap, broken calculator not a brand new one. Unfortunately it’s quite difficult to find a broken TI 84 Plus CE. It’s also very difficult to find replacement parts since TI sources many parts directly from manufacturers. Could you share what’s wrong with your calculator and which part you need? I might be able to help you out.
TheLastMillennial -
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 118
过去 30 天: 534
总计 29,957
