跳转到主内容
Texas Instruments TI-84 Plus CE Battery Replacement
你所需要的
  1. Texas Instruments TI-84 Plus CE Battery Replacement, TI-84 Plus CE Battery Repair: 步骤 1 中的图像 1,1
    • Make sure your TI-84 Plus CE is off before starting the repair.
    • Any objects in your RAM will be removed if the battery is taken out. To ensure your objects are safe, archive them or back them up to a computer.
  2. Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: 步骤 2 中的图像 1,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: 步骤 2 中的图像 2,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door: 步骤 2 中的图像 3,3
    • Locate the 2 Philips screws on the back of your calculator, as outlined.
    • These screws are not to be confused with the 6 Torx T6 scews surrounding the calculator.
    • With a Philips 0 or 00 screwdriver, unscrew the two screws.
    • The two Philips screws will not come out of the battery door, and will stay attached. Do not attempt to remove them completely.
  3. Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: 步骤 3 中的图像 1,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: 步骤 3 中的图像 2,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery door lift: 步骤 3 中的图像 3,3
    • Lift the battery door by grasping one of the two screws that are unscrewed, and pulling upwards.
    • Be sure to lift gently, as little force is needed to get the battery door removed.
  4. Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: 步骤 4 中的图像 1,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: 步骤 4 中的图像 2,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using your nails: 步骤 4 中的图像 3,3
    • Pull out the battery using your nails, by inserting your nail into the small cut out, and lifting up on the battery.
    • As an alternative, you can use an opening tool. Go to Step 5 to see the procedure.
  5. Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: 步骤 5 中的图像 1,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: 步骤 5 中的图像 2,3 Texas Instruments TI-84 Plus CE Battery Replacement, Battery removal using an opening tool: 步骤 5 中的图像 3,3
    • Put your opening tool in the small opening as described in the photos.
    • Gently pull out the battery. You may need to hold your calculator to prevent your calculator from sliding around your working surface.
结论
12等其他人完成本指南。
o355
于03/26/16注册
489 声望
撰写一个指南
8条评论
Where can I buy the replacement batteries?
louis liu - 回复
Hey louis liu, I updated this guide with a link on where to buy the battery. It cost about $12 USD on Amazon: http://a.co/d/iTK2V0v
TheLastMillennial - 回复
I replaced the battery and it worked for 1 week, the battery icon was on the screen which didn’t seem to get charged in full. After a week, the calc didn’t work anymore.
Lesly Simon - 回复
So you're saying when you try charge the calculator it doesn't charge the battery at all? Does the LED next to the charging port turn solid orange when you plug it in? Have you tried a different power source (i.e. your computer or a wall block) or a different cable?
TheLastMillennial -
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 68
过去 30 天: 295
总计 47,301
