跳转到主内容
加入维修社区 - 创建账户
Maxima 在 2009 款车型上进行了重新设计,并在 2008 年纽约国际车展上首次亮相。
Headlamp only works on high beam
2012 Nissan Maxima- Passenger side headlamp only works on low beam. Bulb is fine. How do I determine what else it could be? Ballast? Relay? Fuse?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
promo2110 your lights are fused separately and divided in left and right as well as further into high and low beam. For your Hi beam on the RH side check fuse number 49 which is a 10A fuse in the fuse box (Intelligent Power Distribution Module ;-) in the engine compartment. Sure it could be the control unit or the bulb but check one thing at a time. A simple check would be to flip the lights. If the current RH side works on the LH side and the RH side still does not work you know it’s somewhere in the IPDM CPU etc.
这个答案有帮助吗?
得分 2
添加一条评论
Generally, lamps and other accessories are connected in groups sharing the same fuse, so if there a problem with the fuse then you’ll notice it in different areas, I know this will sound a little bit weird but have you bought the right lamp model? If you don’t know then compare it to the old one and to be sure that the lamp is working fine, you can test it directly with battery.
这个答案有帮助吗?
得分 1
1条评论:
@vertinhol not these lights.
由完成的
添加一条评论
  • The cause: A burned out bulb, or a problem with the high beam switch or relay.
  • The fix: Replace the bulb, switch, or relay.
  • If just one bulb fails to work in either high beam mode or low beam mode, it may be the bulb. Most headlight failures that are limited to just high or low beams are related to a relay or the high beam control switch.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
promo2110 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 41
All Time: 8,473
