跳转到主内容
加入维修社区 - 创建账户
Mazda Millenia 是日本汽车制造商马自达(Mazda)在 1993 年至 2002 年间生产的一款行政轿车。
How to change ignition
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
James Clark ignition what? You need to tell us what the issues are and what you are trying to accomplish. Try to use more than 4 words ....;->
由完成的
@James Clark Do you want to change the ignition switch assembly, if yes, do you also have a security system (anti-theft)? Typically you will need a hammer and very sharp chisel as part of the process but lets see exactly what it is that you need to do first please.
由完成的
Ignition switch?
With lock cylinder, or without?
or,
Ignition module?
Ignition lockout/immobilizer?
Ignition relay?
More information required.
What are the symptoms, or how was the ignition diagnosed as the issue?
Help ‘us’ help you!
由完成的
My bad, just saw someone covered those details, thank Turkey and Duane, they're right on point.
Regards.
由完成的
添加一条评论
1个答案
Here are the instructions for replacing the switch:
Disconnect negative battery cable. Remove steering column upper and lower covers. Remove screw(s) retaining ignition switch to steering column. Disconnect ignition switch harness connector. Remove ignition switch. To install, reverse removal procedure.
这个答案有帮助吗?
得分 0
1条评论:
hope this helps
由完成的
添加一条评论
添加你的答案
James Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 18
总计 1,138
