跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
A1466 cooling fan stops working but works if external 5v is on.
Hello, after replacing keyboard and battery of A1466, there was no issue at first.
But eventually my fan does not rotate....(maybe a week later).
I have an arduino which can test cooling fan with valtage of 5v and ground.
After testing, there is no issue. The fan rotates, but not on the macbook.
There are also 5v, ground, and 3v out in 4 pins of fan connector of Logic board.
I did SMC reset..no work..macbook starts up but no fan running I wonder if cpu will be burned out when cooling fan does not work…
What happened to my fan? Do I need to buy new one?
Update (09/27/2019)
this is with fan
this is without fan
@danj
Update (09/26/2019)
it is 80 degrees but fan does not work…..
@danj
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
@jadelyly - Lets push the system a bit harder your temps are still low.
完成的
OK, not good!
Are you sure your fan is OK? Have you tried a second one?
You'll need to take the logic board out to inspect the back side for liquid damage around the SMC logic and/or damaged/missing components.
Do you have the skills and access to the needed parts to replace damaged or missing components? If not it might be easer just replacing the logic board.
完成的
@danj okay replacing logic board is too expensive..I will buy a new fan and test smc logic component with tester..if result is no good..I will say goodbye to my macbook..thanks anyway
完成的
添加一条评论
2个答案
已选择的解决方案
On your Air fan is controlled by the SMC through some resistors and a MOSFET on the flip side of the board. It may be something got shorted or damaged by mistake along with the replacements.
You might want to check the SMC related cables such as the one going to trackpad and I/O board are well in place, but beside that, one would need to probe the fan circuitry to get some clear answers about the why.
Buying a new fan will be useless since yours works when plugged to an external source. You probably need someone who can provide component level repairs to get it fixed. Running without a fan will probably start causing thermal shutdowns and cook the CPU.
这个答案有帮助吗?
得分 3
6条评论:
I would install this app to help see the thermal load and what the fan is doing TG Pro the free version should offer enough info.
完成的
thanks for your reply, but thre are 5v and 3.3v out in the fan connector of logic board. Does this mean SMC is not the issue?
完成的
@jadelyly SMC doesn't create voltages, it just uses them to modulate signals. I can't say what's wrong without testing and in the end it doesn't really make a difference..does it ?
完成的
@jadelyly - Post a snapshot of TG Pro here for us to see.
These fans have a feedback system (tachometer). Measuring voltages doesn't tell you much unless you understand the logic thats controlling the fan.
完成的
@danj fan diagnostics reauire a registration. is there any way to use this function with trial licesnse?
完成的
显示更多的1条评论
添加一条评论
@arbaman @jadelyly how about removing the fan connector and temporarily connecting test cables from the connector to the fan without the motor controller. Just place a jumper from ground to ground and power to power (5V). If the fan comes on you will know that there is power to the fan. Not turning on would then lead toward an issue with the motor controller circuit (my prime suspect;-)
SSM3K15FV
I added an image of the circuit so I had to make this an answer but should only be treated as a comment.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jade 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 241
