跳转到主内容
The Philips Norelco OneBlade is an electric shaver released around the year 2016. It uses the model numbers "QP2520" or "QP2630."
4 个问题 查看全部
Broken plastic of blade stuck in the oneblade
The plastic that attaches to my one blade broke how do I get it out?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
To get the plastic broken piece out of the one blade you must take it apart. So similar to replacing the servo motor you have to pull the bottom piece of the oneblade off.
Then remove the power button casing but be careful because the plastic at the top attaches to the body where the razor gets put in, so the casing is where the power button sits. Once you take that off you will see lube to the servo. You will see where the blade connects into the plastic housing. If you have a toothpick or something small you can try to push it through the plastic at the bottom as it is very thin and push the broken plastic piece out. May take a few tries but it will work.
I did mine in 10 minutes so it's not too bad
Thank you for reading hope this helped.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I ended up just snapping off the matching broken arm on the blade and it still works fine. Couldn’t get that little piece out even after taking the body apart
这个答案有帮助吗?
得分 1
添加一条评论
Try with a small pair of scissors. Worked in my case
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Piotr Mazur. 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 43
过去 30 天: 157
总计 9,096
