GE Profile occasionally will not pump out
Dishwasher won’t pump out..hose clear…remove standing water manually.. try running again and it works perfectly…3 washings later it does it again….
There is not anything wrong with it. Check the float at the bottom of your dishwasher and make sure it is clear, if it is your dishwasher probably just needs a hard reset. Turn the breaker off for 4-5 minutes, after you turn it back on hold the cancel button down for 3-5 seconds. it will go through a drain cycle and then your dishwasher should be fine.
这个答案有帮助吗?
It worked...but...3 days later it did it again....don’t want to keep shutting breaker off
Always run the disposal before washing dishes.
Removing the filter allows you to clean it thoroughly.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,174
