跳转到主内容
GE Profile occasionally will not pump out
Dishwasher won’t pump out..hose clear…remove standing water manually.. try running again and it works perfectly…3 washings later it does it again….
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There is not anything wrong with it. Check the float at the bottom of your dishwasher and make sure it is clear, if it is your dishwasher probably just needs a hard reset. Turn the breaker off for 4-5 minutes, after you turn it back on hold the cancel button down for 3-5 seconds. it will go through a drain cycle and then your dishwasher should be fine.
这个答案有帮助吗?
得分 1
1条评论:
It worked...but...3 days later it did it again....don’t want to keep shutting breaker off
完成的
添加一条评论
Always run the disposal before washing dishes.
Removing the filter allows you to clean it thoroughly.
  1. Open the GE Profile dishwasher door.
  2. Pull the bottom rack out and set it aside.
  3. Grasp the handle on the filter. Pull straight up to disconnect the filter from the dishwasher base.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 1,173
