跳转到主内容
The HP Compaq 6730b is the "business" edition of the 6730 laptop line released by HP.
Why doesnt my computer turn off
why does my computer not turn off ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Have you tried holding the power button for 5 or more seconds?
完成的
添加一条评论
2个答案
The following command will completely shut down your computer in Windows:
Right click Start icon and select Command Prompt
Type or copy/paste the following in that window:
C:\Windows\System32\shutdown.exe /s /t 0
After your computer has shut off, restart it again and then try testing shutting down as normal.  If computer still won't shut down, please post what operating system the computer uses and your method for shutting the computer down.
这个答案有帮助吗?
得分 0
添加一条评论
use forced turn off i.e
1-hold power button for more than 5 seconds
2- use command prompt shutdown
3- you will be forced to remove the battery if the laptop is completely unable to shut.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ray Hagen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 305
