跳转到主内容
The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
20 个问题 查看全部
HP 6500 wont print black ink
replaced new ink cartridge and realigned and still won’t print from laptop or when I push start copy on printer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Just some thoughts. Maybe check the printers owners manual for how to do a factory reset. Use the "print test page" rather than "copy" (for scanner use). Make sure that your printer is set as either the default printer or select the relevant printer in your operating systems printer settings if you can't print anything at all. HP also has their own diagnostic software, usually installed at the time the new printer is coupled with a computer. Or check their web site for their "Printer Doctor" program (or something like that).
完成的
添加一条评论
1个答案
已选择的解决方案
Are you using genuine HP cartridges ? If so try allowing a full automatic servicing to complete.
Sometimes with be cartridges theirs a few problems that can occur.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Ribaudo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 230
