跳转到主内容
微星所制造的笔记本电脑的维修和支持指南。
222 个问题 查看全部
GS65 Fan rattling noises reported by many users. how to fix?
Hello,
the GS65 model is a pretty popular gaming machine but is plagued by malfunctioning fans. After about 1 month of use, buyers report one (or both) of the fans start making rattling noises. Can you create an MSI GS65 dissasembly guide, including replacing/fixing the fan if possible? I am considering buying this machine, but am reluctant to do so unless i at least know it’s user-fixable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
Hi @joe_q ,
Most repair guides on ifixit are made by people just like you.
If you feel like creating a fan replacement guide for your model laptop if you get one and when you need to repair it then here’s a link that may be of some help.
Dare To Repair: How To Create a Guide.
In the meantime here’s a link to a video that shows the teardown of a MSI GS65 laptop. From about 10:00 minutes on in the video the fans can be seen being removed from the motherboard.
Hopefully this is of some help.
这个答案有帮助吗?
得分 3
1条评论:
Thanks for letting me know, I didn't know how this community works.
完成的
添加一条评论
@joe_q chances of it being torn down by the iFixit team are slim. Remember that their teams are busy with all kind of projects. Now, this isn’t to say it is not going to happen but chances are slim. Also consider that the devices that are being tore down are purchased by iFixit. Maybe you could purchase a MSI GS65 and send it to them and hopefully one of their great techs would find the time to tear it down. Of course, you can purchase one and do your own teardown and post it so the rest of the community gets to see it. It’ll make you a trendsetter for sure. https://www.ifixit.com/Guide/new
这个答案有帮助吗?
得分 2
添加一条评论
Fixing GS65 fan is relatively easy. Disassemble the laptop and heatsink assembly (very small screws) and pull your fan outward. What you will see is a small metal shaft that comes out of a small magnetic hole. Put a very very small amount of olive oil in the metal flange and reassemble the blade assembly. Try rotating it and do not put much pressure while reassembling it (this is the main trick). Rotate the fan and you are good to go.
这个答案有帮助吗?
得分 0
2条评论:
While I moved away from considering the GS65 as a candidate machine for purchase, I think your advice is good except for the olive oil solution. Vegetable oil breaks down in a short time and turns rancid, turning into a sticky goo instead of a fine lube that is required in a fan. This will cause more problems than will solve in the long run. A drop of bike chain lube or any household appliances oil should be much better. Motor oil could also work if you have some around (not the used one).
完成的
Based Italian technician, lol.
完成的
添加一条评论
添加你的答案
Joe Quibler 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 63
总计 4,698
