Is the storage upgradable?
I want to place an SSD inside my laptop to make it run quicker. Is it possible to add an SSD or M.2 to this board?
Yes, you can install a 2.5” SSD drive:
这个答案有帮助吗?
Hi,
Looking at the service manual for the laptop, taken from this webpage if you wish to insert a M.2 SSD rather than a sata SSD you’ll need to change the drive connector board in the laptop
Scroll to p.50-52 to view the HDD removal/connection procedure and to p.55-56 to view the M.2 SSD removal/connection procedure.
On p.56 you’ll find the part number for the M.2 SSD drive connector board.
If you wish to install a M.2 drive, search online for the M.2 SSD drive connector board using the part number only (850946-001) in the search term of your browser, you’ll get results for suppliers of the part
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 367
1条评论
The specs here state " Hard drive 2 TB 5400 rpm SATA" so ssd should be possible. No mention of M.2" though.
https://support.hp.com/us-en/document/c0...
由 prop man 完成的
