The sprung-loaded pins on the motherboard
There are some interesting sprung-loaded pins on the motherboard!
Anyone know what they are used for other than possible test points?
I have an idea.
I have been having problems for the last few days where my MBP will just shut down randomly and it started not long after I lost a screw (the second ) from the base plate. MBP kept shutting down for no obvious reason.
Apple could not find a hardware fault
When at the genius bar I asked them to replace to two screw... since then the MBP has been stable, so I reckon those pins have a grounding/secure point - if no proper contact with the base plate the board issues a shut down, like a close-door replay switch!
So - have I hit on a possible issue, which may solve problems for others?
Antony
1条评论
Not really, a Macbook board would work flawlessly without any grounding to bottom case and outside the topcase too.
由 arbaman 完成的
