跳转到主内容
Repair your Dyson DC 14 vacuum cleaner with a part replacement guide.
Why is the canister loose?
The canister of my DC14 (with wheels) does not stay locked in. I have replaced the canister but it still is a problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
https://www.partswarehouse.com/Dyson-DC1...
Scroll down to the second exploded parts diagram
#4 Cyclone Release Catch
Maybe faulty -> worn, broken, not locking canister
完成的
添加一条评论
2个答案
It sounds weird but is there some debris blocking it from fitting properly? Have you placed the filter the right way around? I do not own one of these but i had this problem with a vacuum i have used. Hope it works!
这个答案有帮助吗?
得分 0
添加一条评论
I have a similar problem that I have resolved. My dustbin canister also seemed too low to align with the ports and the latch. I've since learned that there's a plastic piece on the top of the canister that has broken off. One option is to replace the canister top. I found another solution that seems to be working just fine. I inserted a shim between the hepa filter base and the bottom of the canister, about a quarter of an inch high. That seems to have solved the problem. If it's not satisfactory, I will buy a replacement top. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Deb Kuron 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 1,024
