跳转到主内容
Repair guides and support for the C30, a premium compact hatchback/sports coupe made by Volvo.
9 个问题 查看全部
Where is the maf sensor located
Hi we’re is the MAF sensor located on my Volvo C30 r design 1.6
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@cripper the mass air flow sensor (MAF) is located inside the intake system (green arrow)
Information from here and contains a good write up on how to fix it.
这个答案有帮助吗?
得分 3
添加一条评论
The mass air flow sensor is typically located on the air intake bellows or somewhere in between the air filter box and throttle body. I don’t know your specific vehicle but based on the principle of how the MAF sensor works, it should be there. Usually they are easy to spot as they are cylindrical or somewhat square in shape, about the size of the intake bellows, and will have a wire connector plugged into it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris hall 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 61
总计 1,691
