跳转到主内容
Repair guides and support for motorcycles manufactured by the German motor group, BMW.
17 个问题 查看全部
Damage if battery for a k100 connected up the wrong way
what happens if i connect up the battery up the wrong way and how do i fix it - thankyou
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
firemansam987  tough one to narrow down. Usually you’d fry the rectifier in your charging circuit, the battery may get damaged and the electronics may get fried as well. Check all of your fuses and see what those show. To be more specific we would need to know what it does or does not do.
这个答案有帮助吗?
得分 1
添加一条评论
Alternator or rectifier might be damaged.
Check fuses first… maybe you’ve been lucky.
这个答案有帮助吗?
得分 1
1条评论:
where are the fuses?
完成的
添加一条评论
添加你的答案
firemansam987 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 219
